DMT screen snap hall of infamy
bluewhale
just thought it would be nice if people could post up snaps of the DMT tool readings
just so we can all see what lines should and shouldn't look like
what do people think?
anyway heres mine
8 REPLIES 8
VileReynard
Fixes: 20
Re: DMT screen snap hall of infamy
This mine on an incredibly good day - not been this good for months!
THIS IS ADSL2+
grahamt
OK, just for comparison, here's mine. Note that Taxisofevil and I have about the same downstream attenuation rate. We get very different speeds though. You can't see what my sync speeds are because I'm using a version of DMT that isn't designed for UK lines (it's the only version that works with my ZyXEL P660HW-61 router). The figures are 4538 down and 808 up. IP profile is 3500 (if my sync speed were 4544+ it would be 4000 - Grr.)
I've no idea why I'm on fastpath rather than interleaved. Maybe it's something to do with being banded - my speed improved recently, but I'm tending to go along with Asbo's verdict that I'm probably on a band that maxes at 4.5mb/s. I recently had my bell wire snipped, which helped considerably, and I'm hoping eventually to get a higher speed. But this will take time, and for now I'm happy, as until recently my profile was 2500.
Graham
VileReynard
Fixes: 20
My router has been severely DMT'd - usually I settle for a 6dB noise margin,
but I've got it at a rather aggressive 4.5dB (Daytime) and 3dB (nightime).
If it hangs on just a little longer, I might even achieve a 6.5Mbps Smiley
BTW When the BT engineer called he said I was 1700m from the exchange.
32110
And here's mine. I have used the DMT tool to force SNR to current level using the 10% noise margin setting - it won't go any lower.
VileReynard
Fixes: 20
Did you ever see the Frankie Howerd sketch...
Julius Caesar on the ides of March:-
Infamy! Infamy! - they've all got it in for me! Grin
bluewhale
maybe my lie has been fixed finally....although everyone concerened says that nothing has been changed
as a software developer i've often said that 😉
R_
Can anybody spot the difference between mine and everyone elses.  Thats right no ADSL2+ and no 512 tones.  Embarrassed  I know about the fast path I asked them to turn interleaving off.
coastergrotto
Here's mine.
