Hi, I've got a DLink DSL-504T modem/router, WinXPpro SP1 and ZA firewall. I've tried to set up utorrent using port 50502 setup in the router as per "PortForward" website instructions for the router in question including setting up a static IP address. I've set ZA to allow utorrent access to trusted and internet zones. I've set up utorrent preferences to use port 50502 and tried to check port forwarding using the in program tester under Speed Guide. The problem I have is that it keeps coming back with the old chesnut of "Port 50502 does not appear to be open". Has anyone any ideas?
Cheers
Mike
