DLM
jaym0nd
DLM
Hi
I had my Fibre Broadband activated on Friday 22
Is there DLM active on my line?
Cheers
Fixes: 260
Re: DLM
DLM is always active.. in what context do you mean?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
jaym0nd
Re: DLM
I have accidentally unplugged my Modem from the mains sockets a few times and think I have lost some speed.  Huh
Is there any chance of my profile reset?
Re: DLM
I believe it should automatically increase again as long as you don't disconnect.
Fixes: 163
Re: DLM
On fibre, unfortunately not. This has to be done by an engineer as a result of a fault investigation.
 Chris Parr
 Plusnet Staff
Bright
Re: DLM
As AndyH said, most of the time it should adjust itself automatically. And as Chris said, if your profile has been capped as a result of DLM intervening with what it thinks is severe instability, it needs to be reset by a BTOR engineer. Probably best to leave it for a couple of days and see if it returns to normal.
You can check the actual value of your BT IP profile by running the BTW speed test - click the Further Diagnostics button after the first test to run the second stage which displays your profile.
