DLM strikes again
- Re: DLM strikes again
DLM strikes again
04-11-2011 3:00 PM
One disconnect in over 2 weeks and I lose 1.6 Mb of speed. Which profile predicts my speed, is it the stuck at 8000 PN one or the BT one ?
04-11-2011 3:27 PM
Quote from: JamesM Which profile predicts my speed, is it the stuck at 8000 PN one or the BT one ?
It's the lower of the two!
04-11-2011 3:35 PM
Download speedachieved during the test was - 6350 Kbps
Your DSL Connection Rate :10327 Kbps(DOWN-STREAM), 1215 Kbps(UP-STREAM)
IP Profile for your line is - 9111 Kbps
So I don't understand how my speed has dropped so much.
In other words, BT give me a higher profile than PN but I am stuck with the PN profile because the delta report is faulty ?
04-11-2011 3:42 PM
Having checked the profiles, both are currently set to 8000 so ours isn't stuck presently I'm afraid. Regarding which predicts the speed, I guess whichever is lower will do that. Don't forget we're still getting delta reports at the slower speed as the 88.2% hasn't yet rolled out yet.
Not sure what to suggest regarding the slower speed though, other than the usual master/test socket tests - don't suppose they make any difference?
04-11-2011 3:43 PM
By how much does your noise margin vary?
04-11-2011 4:02 PM
My noise margin fluctuates between 5 and 6 both up and down,
Noise Margin 6 6.
It used to drop to as low as 2 of a night but now never seems to go below 5, maybe thats is why I can now stay connected through the night.
I am hoping that my speed goes back up but I think I am going to be stuck on 7.6 again, and everytime I have been stuck on 7.6 it is because my line has been capped. I can't see a reason for my line to be capped though because I have been connected for about 11 days straight with interleaving off so I can't be getting many errors or I would keep losing connection.
04-11-2011 5:19 PM
04-11-2011 5:24 PM
I am hoping that me disconnecting hasn't banded my line speed again. See how it goes after 72 hours.
I still have a fault open so I just added onto it, it has been a long and painful process with many mistakes, I hate to complain about anything anymore because usually when someone from PN as much as look at my stats, Interleaving gets turned back on and my upstream gets capped again.
04-11-2011 5:33 PM
Quote from: Matt 88.2% hasn't yet rolled out yet.
I thought October 10th was all completed ?
05-11-2011 11:17 AM
05-11-2011 5:57 PM
06-11-2011 10:43 AM
At the moment it is 6 down and 5 up.
06-11-2011 10:56 AM
06-11-2011 2:52 PM
06-11-2011 5:21 PM
