DLM reset request
Inam
DLM reset request
I would like to request DLM reset on my line as my estimated speed on BT site is between 69MB-80MB. I am quite close to my fibre cabinet so I know my line can handle full speed as it did for 18 months without any issues. Currently my profile is stuck on 67MB, don't get me wrong this is still very good but once you get use to higher speeds then you don't want go back do you.
Just to let you know that my profile is stuck on 67MB since December. When BT site is telling me that my line should be able to achieve between 69MB-80MB then I think that's what I should be getting not slightly below in my opinion
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: DLM reset request
If you could pop a note onto Ticket: 83061564 requesting a DLM Reset, I'll give Dan a nudge for you and he should be able to get something arranged for you.
Chris Pettitt
Cloud Environments Engineer
Inam
Done, you are a star Chris much appreciated.
Plusnet Staff
Plusnet Staff
Fixes: 5
Great stuff, I'll give Dan a quick nudge and we'll get that arranged for you.
Chris Pettitt
Inam
@Chris, sorry to be impatient but have you got any update regarding arranging DLM reset. I can fully understand you guys have your hands full with all kind issues lately.
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi Inam,
I'm expecting Dan to get this picked up for you within the next 24 working hours - sorry for the delay.
Chris Pettitt
Inam
Thanks for the quick reply Chris, much appreciated.
Inam
Can some one change my plus net profile to align with my sync profile please, see the pictures below:
Plusnet Alumni (retired) LinnPlusnet
That's been changed for you, Inam.
Inam
Linn you changed my profile to 61MB, what I meant was change it to 72.37MB same as my sync speed.
Apologies, that's been changed correctly for you now Smiley
Inam
Thanks Linn, all seems Ok now!
