DLM reset request
- Re: DLM reset request
DLM reset request
20-10-2020 6:52 PM
Hi
My line speed has dropped since I had some electrical outages in the past month.
Please can a DLM reset be run on my line, line speed is currently restricted to 2Mbps.
Message 1 of 3
(423 Views)
2 REPLIES 2
23-10-2020 4:18 PM
Hi @stephenmcp,
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
Message 2 of 3
(373 Views)
23-10-2020 5:49 PM
Hi , can you tell me when the reset will be done ?
Message 3 of 3
(354 Views)
