DLM reset request / manually set SNR
Dbriggs78
Hello
a couple of months ago i switched to a draytek router, over the course of setting it up, it required a lot of reboots and i think that has locked DLM into my current settings.
at the moment i'm getting an snr margin of 3db and interleaving is stuck on
If possible, could it be manually set to an snr margin of 6db with interleaving off? i would prefer a lower latency connection at the cost of a little download speed for online gaming, I would also prefer 6db over 3 to keep it stable as i'm quite far from the exchange.
Thanks in advance
1 REPLY 1
OskarPapa
Fixes: 64
Re: DLM reset request / manually set SNR
Thanks for your post @Dbriggs78.
I've just switched interleaving off and have upped the SNR margin to 6db.
Please let us know how you get on with it.
