DLM not working? My SNR Margin is stuck at 12db
- DLM not working? My SNR Margin is stuck at 12db
Re: DLM not working? My SNR Margin is stuck at 12db
28-09-2010 4:26 PM
The Line is perfectly stable as you can see below and has been synced for 21 days:
ADSL line status
Connection information
Line state Connected
Connection time 21 days, 5:30:59
Downstream 4,768 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Fast
Noise margin (Down/Up) 13.1 dB / 0.0 dB
Line attenuation (Down/Up) 36.0 dB / 18.5 dB
Output power (Down/Up) 19.8 dBm / 12.2 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 0
CRC Errors (Down/Up) 98129 / 2147480001
HEC Errors (Down/Up) 49547 / 935
Error Seconds (Local) 1
28-09-2010 4:48 PM
the ultimate problem here is the noise margin. When you were at 6dB you had a sync of 7392 and now you're at 15dB you're getting 4768. This is about right as you will lose about 800k for every 3dB increase. The only way to increase this is to see if there is a way to reduce your SNR. As there are errors on the line this is usually about 90% end user. Are you still using the BT hub? Are you in the test socket, extensions etc?
Jojo
28-09-2010 6:03 PM
Yes, I am still using the Home Hub V2 Type A connected to the Test Socket.
Why do you say that there are still errors on the line? The CRC Count on the BT Home Hub always reads 2147480001. It is a "Feechur" of the BT HH!. The HEC errors are not significany over 21 days. It looks very clean to me.
R
29-09-2010 11:11 AM
one of our faults guys had a look at it for me and suggested you try another router to see if it improves.
Jojo
29-09-2010 8:42 PM
Your Faults guy (Tony?) called me yesterday and I have switched Router to a Thomson 585V7. Here are the stats since the re-sync:
DSL Connection
Link Information
Uptime: 0 days, 23:04:30
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,384
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 17.5 / 36.0
SN Margin (Up/Down) [dB]: 0.0 / 15.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 30 / 206
HEC Errors (Up/Down): 8 / 79
Looks pretty clean to me.
30-09-2010 9:44 AM
Ok, well I"m willing to try another reset if you are but if the SNR was to jump back up again then I wouldn't see the point in going down that route anymore. What do you reckon, you up for it?
Jojo
30-09-2010 5:20 PM
I love a good game
I will also replace the Filter so we have ALL new kit on the line.
R
30-09-2010 5:29 PM
Let me know when you've done the filter and I'll go for it.
Jojo
30-09-2010 7:44 PM
DSL Connection
Link Information
Uptime: 0 days, 2:17:49
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,024
SN Margin (Up/Down) [dB]: 0.0 / 14.0
CRC Errors (Up/Down): 0 / 205
HEC Errors (Up/Down): 0 / 90
30-09-2010 7:47 PM
Not sure if I can do it from home but I'll give it a try for you now.
Jojo
30-09-2010 7:55 PM
Ok that's been submitted, it shouldn't take too long to take effect, letme know how it goes.
jojo
30-09-2010 8:01 PM
I'm impressed. None of the women in my life will do anything for me while Eastenders is on!
It has just re-synced and here are the stats: Sync 7008 at 6db
DSL Connection
Link Information
Uptime: 0 days, 0:00:16
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,008
SN Margin (Up/Down) [dB]: 0.0 / 6.0
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 1 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
30-09-2010 8:13 PM
Lol, well this one will Let's hope it stays steady this time. We just need to waiit for the profile to lift now.
Jojo
04-10-2010 12:26 AM
My line stayed synced at 7007Kbps @ 6db for almost 3 days. Arounf 05:00 on Sunday morning, it re-synced @ ~6200Kbps @ 9db. I had a call from Dan at PlusNet at around 11:00 on Sunday and he suggested that there was some noise on my line and it was showing up on a Line test he had done.
We agreed that I would call my Line provider (Primus Telecom) and get them to do a Line Test which should show the errors that Dan had seen. I will call Primus today (Monday) morning and hopefully get them to get Openreach to fix it.
Below are current stats. Note that I re-synced the Router at around 20:00 (Sunday) to check that DLM had really raised my SNR Margn to 9db.
DSL Connection
Link Information
Uptime: 0 days, 4:23:58
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,656
Line Attenuation (Up/Down) [dB]: 17.5 / 35.0
SN Margin (Up/Down) [dB]: 0.0 / 9.0
CRC Errors (Up/Down): 8 / 111
HEC Errors (Up/Down): 3 / 68
04-10-2010 11:05 AM
Hopefully when the source of the noise is fixed you'll stop seeing these errors. The profile should sort itself out too as Jojo says, but let us know if there's anything we can do in the mean time.
