DLM not working? My SNR Margin is stuck at 12db
- DLM not working? My SNR Margin is stuck at 12db
01-09-2010 3:24 PM
About a month ago, I discovered that the Suppressor on my Tumble Drier was arcing and sparking and I replaced it. However, the SNR Margin refuses to come down. I have been re-syncing at 10 day intervals but to no avail.
Re: DLM not working? My SNR Margin is stuck at 12db
01-09-2010 3:46 PM
You seem to have had a good stable connection and bearing in mind you may have discovered the root of the noise issue we could possibly reset the SNR. If we were to do this you would enter a 10 day training period similar to when you were first activated. If you would like me to go ahead with this then let me know.
Jojo
01-09-2010 8:57 PM
Thank you for the quick response. Yes, please go ahead and reset the line. I will wait for your confirmation before I re-boot the Router.
Many thanks, R
02-09-2010 4:14 PM
I've placed the request for the reset. I'll let you know when it completes.
Jojo
02-09-2010 4:42 PM
Your reset has been successful. There's no need for you to reboot, that should be done from this end.
Jojo
02-09-2010 5:17 PM
All I need now is for my Profile to be raised to match.
Many thanks for your very prompt actions.
R
02-09-2010 5:22 PM
That's great news, if it stays like that then you should see a 6500 profile, I'll check it later on tonight for you and then in the morning to see if the BT profile has lifted and then I'll set the PN one.
Jojo
20-09-2010 9:02 PM
My SNR Margin seems to have gone back up to 15db
The line has not re-sync'ed in over 13 days and surely DLM should have recognised the stability of the line and brought it down to the normal 6db.
I suspect that there is a general problem with DLM because two of my referral users are also showing SNR margins of 12db or higher.
Can you shed any light on this?
20-09-2010 9:06 PM
20-09-2010 11:21 PM
I suspect that whatever software (upgrades) applied to the 21CN have also been applied to the 20CN around 6 months ago. Perhaps this is in preparation for the switch over to 21CN.
I am certain that the behaviour changed some time i the last year because I used to get sync speeds > 7Mbps.
21-09-2010 12:07 PM
After resetting it last time I think there would be little point doing it again. It can take a while for the SNR to come down. At this point, I would suggest raising a fault though.
Jojo
21-09-2010 11:14 PM
I am trying to raise a Ticket but keep getting this:
The Smarter Way to Internet
We were unable to complete your requested action. This may be the result of a temporary fault.
Please try again in a few minutes.
Should you require further assistance, please go to our how to get in touch page.
Here are the Router stats just in case you are able to navigate "The Smarter Way to Internet"
ADSL line status
Connection information
Line state Connected
Connection time 14 days, 11:49:53
Downstream 4,768 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Fast
Noise margin (Down/Up) 14.6 dB / 0.0 dB
Line attenuation (Down/Up) 36.0 dB / 18.5 dB
Output power (Down/Up) 19.8 dBm / 12.2 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 0
CRC Errors (Down/Up) 54941 / 2147480001
HEC Errors (Down/Up) 27528 / 560
Error Seconds (Local) 2
UPDATE: I did manage to raise a Ticket .... ID: 35401883
21-09-2010 11:22 PM
At what point do you get that message because I just got to the page where I could type my question. Was it at that point or when you tried to submit it?
Jojo
21-09-2010 11:38 PM
It was in Help Assistant > My Broadband Connection > Broadband Speed
Something different happened at the third attempt and it gave me the options:
Sorry our suggestion didn't help
Please click one of the following.
* Go back and choose another option
* Ask the Support Team your question
I have raised the Ticket now: ID: 35401883
21-09-2010 11:43 PM
Jojo
