DLM after noisy line
wight3030
Evening all,
After having noise on the line which has now been resolved, the noise had reduced my speed from 40Mb to 35.
Question is will DLM intervine after a point and put my speed back to 40? so far my line has been very table since the line has cleared.
12 REPLIES 12
Fixes: 530
Re: DLM after noisy line
It will, but it often takes some time. Did an engineer attend to fix the problem ? If so he should have requested a DLM reset.
wight3030
The problem was fixed outside the property. in the end i didnt need an engineer.
MatthewWheeler
Fixes: 503
Hi @wight3030
Your current DLM profile is "0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off" which means it's unlikely DLM is capping your speed at the moment.
My tests are interestingly still showing a fault so we may need to arrange another engineer to investigate further
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
wight3030
Hi Matthew,
Thanks for the reply and the line test. thats interesting! did the line test pin point where abouts the fault might be?
MatthewWheeler
Fixes: 503
Unfortunately, it's not exactly specific but it points towards an issue around the property known as an "Impairment in copper joint"
wight3030
Thanks Matthew,
I've done some additional trouble shooting myself to make sure its not my equipment (avoid any OR charges).
I've tried two routers, two microfilters, two ADSL cables. All of this was done in the test socket.
Won't budge past 34Mb, however its nice to hear a clear line unlike last weekend. Broadband remains stable its just the speed now.
What are the next steps from here?
MatthewWheeler
Fixes: 503
Thanks for doing that @wight3030
The tests are still showing the same issue so at this point we'd need to get a Openreach engineer out purely to investigate the broadband
wight3030
Hi Matthew,
Did this go to an engineer to investigate?
adamwalker
Fixes: 223
Hi @wight3030 We'd just need to arrange an engineer appointment with you to get that fixed.
Can you let me know if you can be free in one of these slots please?
Monday to Friday
AM = 08:00 to 13:00
PM = 13:00 to 18:00
Adam
 Adam Walker
wight3030
Hi Adam,
Friday PM slot would be best for me.
Have Openreach checked the line outside the property?
ClaudiaG23
Fixes: 25
@wight3030  I've re-run the test and it's coming back clear now.
Has has your connection been?
 Claudia Garner
wight3030
Hi Claudia,
My connection has been stable since the noise on the line has been rectified.
This morning i noticed that my connection has gone back up to 40Mb and the line is still clear.
I wonder if Open reach were working on the lines on a diffrent fault (which my issue might have been connected with) or DLM is operating?
Anyway, I'm happy to leave this for now. i will continue to monitor and will get back in touch if anything goes wrong.
Thanks for your help.
