DLM Updating
- Re: DLM Updating
DLM Updating
21-02-2011 2:09 PM
https://portal.plus.net/my.html?action=data_transfer_speed is showing 2Mb but I have been connected for about 7days at 2.5Mb, is the DLM system working on my line?
3Mb FTTC
3Mb FTTC
Message 1 of 9
(913 Views)
8 REPLIES 8
Re: DLM Updating
21-02-2011 2:57 PM
A profile of 2000kbps is correct for a sync of 2500. You'll need a sync of 2848 for the next threshold of 2500 profile.
https://portal.plus.net/support/broadband/speed_guide/broadband_terminology.shtml#Sync
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 9
(521 Views)
Re: DLM Updating
21-02-2011 3:44 PM
Yes, I know that, I was taking about tge DLM profiles, so Yes, I am syncing at +2848kb/s
3Mb FTTC
3Mb FTTC
Message 3 of 9
(521 Views)
Re: DLM Updating
21-02-2011 4:30 PM
Hi godsell4,
From what I can see your last couple of sessions have not lasted more that 3 days.
Jojo
Jojo
Message 4 of 9
(521 Views)
Re: DLM Updating
21-02-2011 4:32 PM
Reading between the lines - I think he means that the BT IP profile shows 2500kbps but the Plusnet version shows 2000kbps
Message 5 of 9
(521 Views)
Re: DLM Updating
21-02-2011 5:12 PM
It is showing 2000 on the BT side but I think it may be stuck, I'm just running some diagnostics now to see if I can clear it.
Jojo
Jojo
Message 6 of 9
(521 Views)
Re: DLM Updating
21-02-2011 5:30 PM
I disconnected it this morning, to see if getting a new RADIUS event would help kick the system into doing the right thing, but didnt expect that to have an affect for a couple of days at least.
3Mb FTTC
3Mb FTTC
Message 7 of 9
(521 Views)
Re: DLM Updating
22-02-2011 7:52 AM
The BT speedtester says I should be on 2500. See attached.
3Mb FTTC
3Mb FTTC
Message 8 of 9
(521 Views)
Re: DLM Updating
22-02-2011 3:59 PM
HI godsell4,
I've just tried making some changes to see if I can get that upped. Give it about 15 mins and you should see the difference.
Jojo
Jojo
Message 9 of 9
(520 Views)
