DLM Reset
MinniMan
DLM Reset
Can someone reset the DLM on my line and turn off interleaving? My speed has been stuck on 67 mbps for a while and my ping has increased to 30ms.
13 REPLIES 13
Fixes: 1,495
Re: DLM Reset
Moderators Note
This topic has been moved from Full Fibre to Broadband
Fixes: 1,662
Re: DLM Reset
I've had a look and I can see the latest profile for your line is "Downstream: 0.128M-80M with no error protection. Upstream: 0.128M-20M with no error protection" so there's no banding or artificial restriction on your speed.
Is your router plugged into your master telephone socket? If you haven't already, can you try the test socket explained Here? That'll rule out any issues with the internal phone wiring of your property.
MinniMan
Re: DLM Reset
I have 5C MK4 master socket and I don't have microfilter for the test socket.
Fixes: 1,662
Re: DLM Reset
Ah okay, do you still have the box for the router we've sent you? We'd have included a microfilter with it.
MinniMan
Re: DLM Reset
I don't have the box anymore.
Fixes: 1,662
Re: DLM Reset
OK no problem. What type of master socket do you have? Is it an Openreach 5C?
MinniMan
Re: DLM Reset
Yes, 5C. It's the one that looks like the attached image.
Fixes: 1,662
Re: DLM Reset
Cool. Yeah that's the latest. As your speed's below the estimates of your line, I think it's worth arranging an Openreach engineer to take a closer look. When could you be available for a visit? The engineers are available weekday timeslots (and occasionally Saturday's) of 8am to 1pm or 1pm to 6pm.
MinniMan
Re: DLM Reset
I live on the top floor in a block of flats and both my lifts have broken down so I don't want to put the engineer at a inconvenience. Are you sure you can't just reset the DLM on my line or on my profile?
Fixes: 387
Re: DLM Reset
@MinniMan As @Gandalf has finished for the day, I'll answer for him: With the details posted in message #3, there is nothing on PN's side they can adjust remotely.
Fixes: 1,662
Re: DLM Reset
I've done a DLM reset for you which should go through within 24 hours, but I'm not confident that it'll help.
If it doesn't help then we'd likely need to inconvenience an engineer.
MinniMan
Re: DLM Reset
The reset happen, my speed and ping are back to normal. Thank you
Fixes: 1,662
Re: DLM Reset
Awesome and the engineer will be happy that they don't have to climb all those stairs.
Let me know if there's anything else you'd need help with. Smiley
