DLM Reset
MinniMan
DLM Reset
Can someone reset the DLM on my line?
2 REPLIES 2
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: DLM Reset
@MinniMan  Yes someone at Plusnet can probably do a DLM reset but why do you ask, is your line banded (capped) at a low speed?  Your post is rather lacking in detail, a bit more information would be helpful, such as expected speeds and actual modem sync speeds.
SammyM
Fixes: 96
Re: DLM Reset
Hiya @MinniMan
I'm sorry for the late reply, we're busier than usual and it is taking us longer to get back to you guys than we would like.
I have tested your line and I am unable to locate a problem, do you mind getting back to me with more detail on the issue you are experiencing?
 Sammy M - Sheffield Team
