DLM - DCT, please check my interleaving status
- Re: DLM - DCT, please check my status
12-12-2013 7:00 PM
Hi DCT,
Please can you check if DLM is currently switched on for me. Latency bump at 05:30 today.
Don't think it's the gateway this time.
EDIT:
Speed seems nominal again, but latency still increased.
EDIT:
Message 1 of 7
(1,198 Views)
6 REPLIES 6
12-12-2013 7:27 PM
Are you on FTTC? If so I'm not sure that DCT can see and, even if they can, they can't do anything about it...
Message 2 of 7
(815 Views)
12-12-2013 7:35 PM
@pwatson,
I am on FTTC.
Yes, they can see.
Thank you for the concern but for my own personal information, I would like to know. Thank you.
EDIT: For instance, if there is another problem on my line besides DLM causing my bandwidth issues, I would need to know to begin getting the problem resolved.
I am on FTTC.
Yes, they can see.
Message 3 of 7
(815 Views)
13-12-2013 7:37 AM
DLM is on, you're on an FTTC line, DLM is on for all FTTC lines, we can't turn it off.
Unless the latency increase is actually causing any problems for you, then I really wouldn't worry about it. Sometimes we get a bit carried away looking at stats but the line is running perfectly fine.
Message 4 of 7
(815 Views)
13-12-2013 9:15 AM
@Chris
Thanks and I understand that DLM is used on all FTTC based connections.
I should've been more specific: Please can you check if interleaving is enabled on my line at present.
Message 5 of 7
(815 Views)
Re: DLM - DCT, please check my interleaving status
13-12-2013 9:48 AM
The current FTTC profile for your line is 40M-80M Downstream, Interleaving Off - 10M-20M Upstream, Interleaving On
So interleaving is off on the downstream at the moment.
Message 6 of 7
(815 Views)
13-12-2013 9:57 AM
Thanks Chris,
Looks like interleaving switched on on my upstream, increasing my latency approx 8ms.
Hopefully it doesn't get any worse.
Message 7 of 7
(815 Views)
