DISASTROUS service... almost a month without broadband... use BT instead
- Re: DISASTROUS service... almost a month without b...
10-06-2013 11:32 AM
To cut the long story short, after numerous phone calls and updates on our open issue from plusnet, it’s been almost a month and we’re still without functioning internet… forget working from home, forget streaming videos, forget downloading even some of the larger email attachments… the connection is intermittent, and the speed is, at most, in the range of 0.3 Mb/sec.
We had to arrange for two different engineers to get access to our flat… Finally, the fault has been identified as being with BT Openreach cables, and since then the updates have been pretty much the same – whether on the phone, or through the website. Example: “I have spoken to Openreach further today for an update and the offline team have again been unable to gain an update from the relevant department.”
On top of that, PlusNet support themselves seem a mess, last time I called they were surprised that I didn’t have an update FOR THEM from the BT engineer, rather than this working the other way round i.e. plusnet having an update for me.
Overall a large mess, I try to sympathise with PlusNet to some extent, as clearly a lot of the problems stem from the fact that Openreach are just not responsive enough to the issues raised by Plusnet on my behalf… But this needs to be worked out between the two companies, and I just need to have functioning broadband to be able to work and get what I’m paying for. The conclusion can only be one – PAY A BIT MORE AND GET YOUR PHONE AND BROADBAND FROM BT DIRECTLY..
I’ll try to post updates here but last time I spoke to Plusnet, I was told that it can be “weeks” before the cable is sorted
Re: DISASTROUS service... almost a month without broadband... use BT instead
10-06-2013 1:25 PM
I'm sorry that this has happened. By the look of it there's an underground wiring issue that needs to be resolved, and if that means street access whether for a dig or manhole it also means going through the local council etc - I'm guessing here, but that's usually what takes the time on these kind of things.
I assure you we'll keep chasing, but any other ISP - including BT Retail, who aren't actually the same company as BT Openreach, who'll be doing the work.
We'll be chasing for another update tomorrow as per your ticket, I hope it's good news.
10-06-2013 1:40 PM
jim:quote
10-06-2013 3:10 PM
17-06-2013 2:48 PM
Both my points stand, (A) the communication between PlusNet and Openreach is obviously completely broken, and Plusnet aren’t able to get any kind of specific date out of them. They quote Openreach people being out of office as the reason for that, which to me sounds plain ridiculous, I’m sorry… (B) Plusnet aren’t great at following up on my outstanding issue, it’s me having to chase them for promised updates most of the time.
17-06-2013 4:45 PM
18-06-2013 10:58 AM
With that in mind we've escalated the issue as we need to push back harder on our suppliers. I'm really sorry that this hasn't happened until now and I hope that this gains the case the extra attention it needs.
It might not be myself chasing for updates on this issue but I'll make sure that we're updating you as often as possible.
Adam
EDIT: An update has come through so I'm just going to update your ticket now.
28-06-2013 9:14 AM
Doesn't stop them from charging me £33 in monthly payments... If that's not ridiculous, I don't know what is.
28-06-2013 9:18 AM
I will make sure this gets chased today for you to see if we can find out any more news.
With regards to billing we do fully intend to refund you for the time you've been without service after this has been resolved plus an additional goodwill gesture to show there's no hard feelings.
Adam
28-06-2013 10:40 AM
He's already a month in credit with his payments, you should be able to put the account on hold so that no further payments are taken until the issue is resolved. If you can't do that why can't you put a £33 credit on his account to nullify the next payment before it's taken?
17-07-2013 10:20 AM
18 May: ticket opened
30 May: (after 2 engineer visits): further work will be required.
6 June: “I have spoken with Openreach for a further fault update but they couldn't get in touch with the control department that offers this after numerous lengthy attempts.”
7 June: “I have spoken to Openreach further today for an update and the offline team have again been unable to gain an update from the relevant department.”
12 June: “The fault is currently still with the traffic management team whilst work is carried out to replace underground cables”
15 June: “I have contacted Openreach again today in regards to what is happening with the traffic management that is needed in order to resolve this issue.
At present we have been unable to get a set date for this to happen. Openreach have now submitted an internal escalation to have this looked in to as a matter of urgency on your behalf.”
17 June: “I have spoken to Openreach directly this morning. They have advised that all paperwork has been submitted and we are awaiting commitment from a "Traffic Management" team. They have advised that they will be able to update us on this within 7 days. “
19 June: “Openreach have accepted my escalation request that was sent on the 17th June. They have advised that your fault is linked with a common fault in your area and that "Traffic Management" needs to be requested and actioned before this work can go ahead.”
24 June: “I have checked for an update regarding your fault with BT Openreach today. As this is a common fault in the area that may be affecting several customers, more work is required to resolve the issue. A survey team is scheduled to visit the fault location on the 28/06/13 as Traffic Management is required.”
26 June: “Unfortunately a fix will not take place on your fault in the next few days. The survey needs to take place so that the job can then be planned and dates then given for the work to go ahead. Traffic management will be needed with 2 way traffic lights so that work can go ahead to resolve the fault.”
4 July: “Thank you again to this long period of time for this fault to be resolved. We have spoken to BT Openreach today and again they have been unable to give us a date for when the fault is due to be resolved.”
7 July: “Our suppliers have advised that they are currently in the process of appointing a Precision Testing Officer to work on your line, to determine the exact cause of your fault. We've been advised to expect an update on this on 10/07/13.”
11 July: “I have checked for updates on your fault today and BT have informed me that a precision officer was due to attend yesterday, they were unable to get information following this as they could not get hold of the control department but the review date given is tomorrow.”
12 July: “I have contacted our suppliers today for an update on the progress of your fault. They have been unable to provide an update as to the work that went ahead on 10/07/13.”
13 July: “Unfortunately we have not yet received a response from the escalations team at Openreach and we were not able to get any further information at this time as the department that would be able to provide us with this is currently closed. We have been advised to check for further updates after 7am on Monday. “
15 July: “I have checked for updates on your fault today and BT have informed me that an engineer is currently working on the fault, the control team have advised to check again for details by the end of the day.”
16 July: I’m told that fault has been fixed, yet broadband is just as unusable as it has been for the past 2 MONTHS…
17 July: “I have reviewed the engineer's notes following the resolve of your phone fault and it appears they have been able to resolve the issue without further underground work. Engineers will always endeavour to do this where possible, as it can prevent further delays. It is normal for broadband speeds to be reduced for around 72 hours following work on your line as it settles back down”
BOTTOM LINE: we’ve been waiting 2 months for the issue to be resolved; 90% of time when I chased up on the open ticket, I was told to wait 1 / 2 / 7 days for an update/ETA/issue to be resolved; apparently it’s taking that long because underground work is needed; after 2 months I’m told that underground work is not needed after all; apparently the issue is now fixed; when I complain that it clearly isn’t, I’m told to wait another 72 hours…
THIS IS A JOKE..
17-07-2013 10:39 AM
Correctuion - it isn't a joke it is a bloody disgrace and somebody - OFCOM - should jump all over this bunch of incompetent idiots
Quote from: PavZ THIS IS A JOKE..
17-07-2013 2:25 PM
I'm asking because the whole point here was that the service was ridiculously slow, and intermittent, so I can't see how they could have concluded that it's fine now, but only expect the fix to start working within 72 hours... I'm very confused.
17-07-2013 2:59 PM
Quote from: PavZ More importantly - is it right that "line normally takes 72 hours to settle down and speeds to return to normal levels"?
That could be the case, depending how DLM is operating.
PN staff should be able to see some/most of your connection stats and advise if that is the case.
Given the background to this they ought to be doing that anyway and intervening if appropriate.
17-07-2013 3:15 PM
Day 1 Phone Line becomes very noisy.
Day 3 Two Openreach engineers arrive. After 2 hours decide the fault is located 2m from their manhole. The work they do changes the line from noisy to dead.
Day 9 Contractors arrive to dig a hole. Openreach engineer comes but concludes the hole is in the wrong place and it would be better to run a new duct with new wires.
Day 10 Contractors return to fill in the hole.
Day 15 Still waiting for the next contractors to lay the duct.
