DHCP IP camera
Tigerman1965
DHCP IP camera
Hi how do I enable DHCP on my TG528n technicoulour router so my IP camera can connect to the network please.
Where is this in the settings?  Roll eyes
Fixes: 20
Re: DHCP IP camera
DHCP is on by default, that is how your PC/tablet etc gets connected to the network.
Tigerman1965
Re: DHCP IP camera
Thanks.
I can't get my IP camera to connect to network do you know any setings that would prevent an auto configuration wizard to not find router ? So infuriating
Fixes: 20
Re: DHCP IP camera
Usually it is something in the settings. Can you connect directly to the camera ? Or does it have a reset button? IF so try pressing that it might be fixed on a different ip range.
