DGTeam firmware
randpwar
DGTeam firmware
I’ve recently seen a couple of posts that refer (example below) to this firmware for the Netgear DG834 router. Does this firmware replace the version downloaded from Netgear? Is it safe? It appears to offer extra functionality?
I’d be interested to hear users views
Kind Regards
Rob
http://community.plus.net/forum/index.php/topic,85836.0.html
Fixes: 172
Re: DGTeam firmware
I have used it before and it worked well, it is safe though as with all firmware upgrades there is a slight risk that it won't apply properly.
So make sure you have the netgear recovery tool and instructions ready Smiley
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
chrisoldinho
Re: DGTeam firmware
Or the 100% failsafe NFTP Smiley
