DD WRT configuration for plusnet
Lexius
Hi, the router supplied with my account is not really up to the job. So I got another router with DD-WRT on but dont seem top have had much success configuring it
I have spent 2 days trying to configure dd wrt for plus net, has any one managed to do this successfully?
I have tried a lot of things reboots, re-sets.
besides the:
connection Type: PPPoE
User Name        : myusername@plusdsl.net
Password          : ************
what other setings need changing
when I try to 'Connect' i breifly get a screen telling me "Connection Type:    Disabled"
Thanks in advance for any help
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: DD WRT configuration for plusnet
Fixes: 396
PPPoA for a start unless you are on fibre
@Jim,DD-WRT doesn't work with ADSL modem/routers ( well actually there's a prototype which works with just one, the WBMR-HP-G300H ) it's designed for WAN routers as used on fibre.
@lexius, There was a problem on DD-WRT V24 with PPPoE connections. V24 SP1 fixed it http://www.dd-wrt.com/phpBB2/viewtopic.php?t=32311&postdays=0&postorder=asc&start=0
Lexius
thanks for thr responses, I cant see an option for PPPoA anyway, just PPPoE and im on broadband/ adsl.
Part of my 2 day attempt to work out the config was spent reading that post on dd-wrt and I have V24 SP2 installed.
any other ideas?
Oldjim
Resting Legend
Fixes: 63
The next question is which router
Lexius
Linksys WRT54-GS v4
Oldjim
Resting Legend
Fixes: 63
I don't think that includes an ADSL modem so it won't work unless you use it as a wireless access point from your existing router
Fixes: 396
Correct Jim.
@Lexius, How are you connecting that to your ADSL line ?
Lexius
I am connecting it by plugging the telephone line in the back of the modem.
So are you saying that even though it has the correct connection in the back for the telephone jack, that must just be for a dail up line and not ADSL?
Oldjim
Resting Legend
Fixes: 63
If you look at the basic installation guide you will see that it needs a modem in front of it
From the guide - see this picture
Alternatively an ADSL router see second picture
Lexius
ok that was pretty dumb of me, thanks - I didnt actually have the manual - it was missing from the router box, but that s no excuse really, as I am sure its easily downloadable.
thanks again.
