D/load speed still wrong
- D/load speed still wrong
06-11-2009 12:15 PM
Connection Speed 2368 kbps 448 kbps
Line Attenuation 56 db 15.5 db
Noise Margin 12 db 21 db
BT speed test........ Download speedachieved during the test was - 204 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2368 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Plusnet speed test.......
Re: D/load speed still wrong
06-11-2009 3:02 PM
06-11-2009 3:05 PM
Are you connected to the router by wire or wireless
06-11-2009 3:20 PM
WICKERSLEY
Estimated line speed:
3.0 - Checked on 2009-11-06 13:25:44
Current line speed:
2000
06-11-2009 3:22 PM
Is it possible to check when wired
06-11-2009 3:36 PM
06-11-2009 3:47 PM
06-11-2009 4:04 PM
06-11-2009 4:10 PM
06-11-2009 4:28 PM
06-11-2009 4:29 PM
06-11-2009 4:52 PM
