D-Link DIR868L compatibility
Routerquest
Can anyone tell me if the D-Link DIR868L router is compatible with my plus net fibre.  Would it connect straight to the BT open reach  modem.
Currently use the supplied tecnicolour router.
Fixes: 205
Re: D-Link DIR868L compatibility
Hi there
From a quick search it appears it should work
It has a ethernet WAN port so you would just plug the ethernet cable from the modem into that port and go through the setup to get you online
 Matthew Wheeler
Routerquest
Thanks for your quick response.  I have tried this and the router remains with the LED as orange.  The manual says the orange LED means the connection is good but can't connect to the internet.  Trouble is the manual doesn't say what to do if it remains orange.
Any ideas ?
Fixes: 205
How do you have the connection set up in the settings?
It should be set to PPPoE with your connection username being username@plusdsl.net obviously replacing username with the one that you log into our website with
 Matthew Wheeler
