D-Link DIR868L compatibility
- Re: D-Link DIR868L compatibility
26-07-2014 3:34 PM
Can anyone tell me if the D-Link DIR868L router is compatible with my plus net fibre. Would it connect straight to the BT open reach modem.
Currently use the supplied tecnicolour router.
Message 1 of 4
(841 Views)
3 REPLIES 3
26-07-2014 3:53 PM
Hi there
From a quick search it appears it should work
It has a ethernet WAN port so you would just plug the ethernet cable from the modem into that port and go through the setup to get you online
Message 2 of 4
(516 Views)
26-07-2014 4:28 PM
Thanks for your quick response. I have tried this and the router remains with the LED as orange. The manual says the orange LED means the connection is good but can't connect to the internet. Trouble is the manual doesn't say what to do if it remains orange.
Any ideas ?
Any ideas ?
Message 3 of 4
(516 Views)
26-07-2014 4:31 PM
How do you have the connection set up in the settings?
It should be set to PPPoE with your connection username being username@plusdsl.net obviously replacing username with the one that you log into our website with
Message 4 of 4
(516 Views)
