Current speed
- Current speed
Current speed
13-11-2009 11:17 PM
Hi folks,i have just come out of my training period and been told my line will support 7 meg but earlier today i did a speed test at 6.5 meg which was great but later on when i did another it had dropped to 2 meg , is this normal i did the speed test in peak time but the second one out of peak time,thanks in advance.
Message 1 of 7
(1,142 Views)
6 REPLIES 6
Re: Current speed
13-11-2009 11:44 PM
Speed tests can vary considerably from moment to moment, and from speedtester to tester.
Which one did you use? Try the PN one http://www.mybroadbandspeed.co.uk/ .
If you get an unbelievable result from any tester, run it again straight away. (You have to wait 3hrs with the BT one though).
Edit: Note using speedtesters does use up your bandwidth mind.
Message 2 of 7
(551 Views)
Re: Current speed
13-11-2009 11:54 PM
Thanks for reply, yes used the plus net one and did it couple of times so got same result.
Message 3 of 7
(551 Views)
Re: Current speed
14-11-2009 12:16 AM
What sort of results are you getting now?
Message 4 of 7
(551 Views)
Re: Current speed
14-11-2009 6:47 AM
no comment
Message 5 of 7
(551 Views)
Re: Current speed
14-11-2009 8:01 AM
Message 6 of 7
(551 Views)
Re:Current speed
16-11-2009 1:27 PM
Your IP Profile is still showing at 7150, as is the profile on our side so that's not the cause of the slowdown.
Is it just during peak hours you're seeing the slowdowns or does it happen at other times of the day too?
Message 7 of 7
(551 Views)
