Current speed estimate too high and wrong
- Current speed estimate too high and wrong
12-06-2012 11:25 AM
Hi folks,
I received this surprising notification today:
Phone exchange:
COTGRAVE
Estimated line speed:
1.0Mb (Accurate to within +/- 1Mbit) - Checked on 2012-05-18 22:23:42
Current line speed:
7.15 Mb
My Line stats:
adsl: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 900 Kbps, Downstream rate = 3072 Kbps
Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 3040 Kbps
Link Power State: L0
Mode: G.DMT
TPS-TC: ATM Mode
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.3 17.0
Attn(dB): 63.5 31.5
Pwr(dBm): 18.1 12.1
The above synch is what I expected it to be. Any thoughts on why Plusnet are seeing 7.15?
Phone exchange:
COTGRAVE
Current line speed:
7.15 Mb
My Line stats:
Status: Showtime
Retrain Reason: 1
Mode: G.DMT
TPS-TC: ATM Mode
Trellis: ON
Down Up
SNR (dB): 9.3 17.0
Attn(dB): 63.5 31.5
Pwr(dBm): 18.1 12.1
Message 1 of 3
(815 Views)
2 REPLIES 2
Re: Current speed estimate too high and wrong
12-06-2012 11:35 AM
They aren't.
That is the default number until they receive an update from the BT systems - it is intended to follow the IP profile as given by the BT speedtest but sometimes the report doesn't come through properly
Message 2 of 3
(310 Views)
12-06-2012 11:58 AM
Thank you.
Message 3 of 3
(310 Views)
