Current line speed
dor
Current line speed
IP profile of line has dropped from 10.84/0.83 in March to 6.88/0/83 (I can PM stats if required). Can someone advise why this drop. Also, can line stats be checked as router drops out a lot or has to be robooted.
1 REPLY 1
Fixes: 1,552
Re: Current line speed
Hi there.
Line tests aren't showing the cause of the speed drop, but based on a 24 hour snapshot of the connection your line is erroring every 4 seconds as shown below.
xDSL Status Test Summary
Sync Status: Circuit In Sync
General Information
NTE Status:   NTE Power Status: PowerOn Bypass Status:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 15.6 31.0
SNR Margin: 6.5 8.6
Errored Seconds: 1 5
HEC Errors: 1
Cell Count: 3139243 4892430
Speed: 1176 7875
Maximum Stable Rate (KBPS): 10208 Fault Threshold Rate (KBPS): 8166
Mean Time Between Retrains (Seconds): 86322 Mean Time Between Errors Upstream (Seconds): 4111
Indicative Line Quality: R Mean Time Between Errors Downstream (Seconds): 4
I'd recommend running through the troubleshooting steps at http://faults.plus.net completing the process to report a fault to us if you're still having issues.
Let us know over here when you have raised the fault and we'll be happy to take another look.
