Current line speed
- Re: Current line speed
Current line speed
26-06-2018 9:04 AM
IP profile of line has dropped from 10.84/0.83 in March to 6.88/0/83 (I can PM stats if required). Can someone advise why this drop. Also, can line stats be checked as router drops out a lot or has to be robooted.
26-06-2018 10:50 AM - edited 26-06-2018 10:51 AM
Hi there.
Line tests aren't showing the cause of the speed drop, but based on a 24 hour snapshot of the connection your line is erroring every 4 seconds as shown below.
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | PowerOn | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 15.6 | 31.0 |
SNR Margin: | 6.5 | 8.6 |
Errored Seconds: | 1 | 5 |
HEC Errors: | 1 | |
Cell Count: | 3139243 | 4892430 |
Speed: | 1176 | 7875 |
Maximum Stable Rate (KBPS): | 10208 | Fault Threshold Rate (KBPS): | 8166 |
Mean Time Between Retrains (Seconds): | 86322 | Mean Time Between Errors Upstream (Seconds): | 4111 |
Indicative Line Quality: | R | Mean Time Between Errors Downstream (Seconds): | 4 |
I'd recommend running through the troubleshooting steps at http://faults.plus.net completing the process to report a fault to us if you're still having issues.
Let us know over here when you have raised the fault and we'll be happy to take another look.
