Current line speed of 0.5mb
jamieharrop
Suddenly since yesterday our broadband connection has become unbearable. Even trying to watch BBC iPlayer in the lowest quality setting isn't working.
Checking the line via my landline it seems fine.
Any ideas why this speed has suddenly dropped and what I can do?
Jamie
oldsch00l
Re: Current line speed of 0.5mb
Hi Jamie, I feel your pain. I'm having similar issues - although more like 0.2mbps for me!
In the first instance follow the steps in this topic and post your results.
Then you're probably looking at logging as a fault at https://faults.plus.net
Cheers,
Ross
Plusnet Staff
Plusnet Staff
Fixes: 159
Hi Jamie,
Your line seems to be erroring quite frequently, I've made a change to the line settings to try and combat this. Can you monitor it and let us know how it's performing over the next 24 hours.
 Chris Parr
 Plusnet Staff
jamieharrop
Thanks Chris.
I reported a fault last week and PlusNet support applied a fix which took the 'current line speed' in my PlusNet members area from 0.5mb to 3.4mb
The speed has now dropped to 2.2mb, so while not as bad as 0.5, it's still a sharp drop compared to last week.
Thanks!
Jamie
Fixes: 33
I've just submitted an SNR reset to 6db which should hopefully get you back to downstream speeds in that region.
 Adam Walker
