Current line speed change
bradw
IP Profile for your line is - 43.13 Mbps
Current line speed: 24 Mb
Could that be fixed please?
SpendLessTime
Aspiring Hero
Fixes: 53
Re: Current line speed change
At the weekends, there may not be any staff on the forum. Best off if you call support.
bradw
I see someone (or something) updated it to Current line speed: 37.4 Mb
Download speed achieved during the test was - 22.65 Mbps
For your connection, the acceptable range of speeds is 30.19 Mbps-43.13 Mbps .
Additional Information:
I guess that wasn't it then...
Your speed profle was automatically updated. I've checked your sync and it's showing it at 38.6Mbp/s which gives you the correct speed profile.
What's your IP profile currently at if you run another speed test?
bradw
Getting ~34mb now!  Smiley
BTW wasn't working when I tried though
Have you tried in another browser to see if the speed test will run?
