Current fault response time
ardiff
I logged a fault with my ADSL 3 days ago, but have yet to see evidence of any testing or anyone picking up the ticket. Is this normal?
Fixes: 231
Re: Current fault response time
Our faults team aim to respond to them within 72 hours but at the moment they're a little behind.
I'm picking this up for you now.
 Matthew Wheeler
ardiff
I appreciate your efforts, Matthew, but it's now 12 days since I first reported a problem and I'm still seeing speeds reported in bps - forget about Mbps - and interference from any router I connect is making my phone line unusable. It's no comfort to know support are a little behind when I'm paying for a service I simply haven't been receiving these past 2 weeks.
Fixes: 167
This may be a very basic question, but I see you say different routers have been tried. Have you tested a different filter/cable between the socket and the router?
 Chris Parr
 Plusnet Staff
ardiff
Hi Chris. The router's into an Openreach-fitted filtered faceplate, but I have tried swapping cables between it and the router to no avail.
Fixes: 167
I see there's an engineer booked for today, fingers crossed they can detect and fix the issue.
 Chris Parr
 Plusnet Staff
ardiff
Openreach have now fixed a hard fault on my line and my router stats look very promising. However, I'm not seeing the benefit in actual throughput. Please will somebody check if there are restrictions on my line and have them removed if there are? Thanks.
Fixes: 167
Checking now, will report back shortly.
 Chris Parr
 Plusnet Staff
Fixes: 167
I've set the profile on our side to where it should be, however at the moment the BT IP Profile is still showing at 500. Can you run the BT speedtester at http://speedtest.btwholesale.com/ and complete the 'further diagnostics' section to see what that profile is set at?
 Chris Parr
 Plusnet Staff
ardiff
Hi Chris. I've never succeeded in getting further diagnostics to run. I always get the message "The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider." Is there another way I can check?
Fixes: 231
It looks like the profile on our suppliers systems might be stuck.
Leave it with me.
 Matthew Wheeler
