Could you raisemy snr level please?
richardhead
Good morning,
For the last few weeks my snr level is hovering around the 0 - 0.5 level and i think this is causing the random disconnections.
I was getting them a few months ago but they seemed to have eased off up until now.
I don't want it raised to much as i would lose a lot of speed, and i am using a billion 7800n which can handle low db of around 2 - 3db anyway.
Thank you very much!.
Fixes: 5
Re: Could you raisemy snr level please?
Crikey that's way too low. I'm doing a few line tests now to see if there are any faults seen. If not, I'll get it sorted for you with the aid of an SNR change.
 Tony T
Fixes: 5
If you've not seen a change in a few hours, please post back.
 Tony T
richardhead
Quote from: plusnettony
Hahaha, yeah it has taken me by surprise to. I am currently at 0.8, but will keep a watch and see if it changes. Thanks mate!.
Fixes: 5
I changed the target 3db on the downstream, I'd prefer 6db normally, and it still maybe worth changing to 6 ... we'll see how it goes before I make any more changes.
 Tony T
richardhead
Hello again Tony
The snr has inded increased to 3db and all good so far thanks. If the connection deteriorates i will get in contact again.
Thanks once again!.
mwarby
I'm kinda surprised BT wholesale let the SNR get below 1dB on a resync, I thought 6dB(target) was as low as it went without hacking/tweaking the modem
Fixes: 62
nope - it often goes down to 3dB on a good line on ADSL2+
Fixes: 5
I've just checked it again, and it's still showing at 3db, and the line has been stable overnight.
 Tony T
