Could you please increase my SR margin to 6.0?
Cagney1994
Hi. I seem to suffer from a few dropped connections due to my SNR margin being about 3.0. As the thread title states, would it be possible to increase it to at least 6.0? Thanks.
Fixes: 46
Re: Could you please increase my SR margin to 6.0?
Hi, yes we can give that a try for you. That should take effect within the next few hours.
Let us know if the disconnections continue as we'd then need to raise a fault.
 Adam Walker
Cagney1994
@adamwalker - Thanks Adam, but I got in touch with PN Live chat yesterday and it seems it's already been done.
And does the SNR for both upload and download adjust itself automatically? - Even if it was set at 6.0 or any other figure?
The reason I ask is because earlier on today, it went down to 5.9. Not much difference I know but I'm just wondering if it'll go down even further and then the dropped connections will start again.
Fixes: 46
No worries,
Yes, the upload SNR is set automatically unless we specifiy a margin.
Howe are thing looking with your connection today?
 Adam Walker
Cagney1994
@adamwalker - Sadly I may have suffered another dropped connection or two. And the download SNR margin has decreased to 5.4 (at the moment).
Could you specify a permanent margin of 6.0 or above?
Plusnet Staff
Plusnet Staff
Fixes: 159
We can hard pin a target SNR, however this will fluctuate throughout the day as different things happen along the line changing the noise levels etc.
 Chris Parr
 Plusnet Staff
