Could you increase my SN Margin please ?
Cagney1994
Hi Mods
As the title states, could you please increase the download margin to about 6.0 ? - The reason being is that I keep getting disconnected every couple of hours or so. At the moment, it's :
SN Margin (Up/Down) [dB]: 6,2 / 3,0
Thank you Smiley
Fixes: 257
Re: Could you increase my SN Margin please ?
mods are just customers like yourself Smiley
hopefully one of the staff team will pick this up for you.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Cagney1994
Thanks dvorak.
And looks like the connection dropped again. How do I raise a ticket ?
Thanks.
Fixes: 212
I can see you've spoke with our live chat team who have changed this for you.
Let us know if you have any further issues.
 Matthew Wheeler
Cagney1994
Hi Matthew.
Unfortunately it's still at 3.0  Sad
Fixes: 212
We put through the reset so I'm not sure why it's still at 3db.
I've contacted a team within our suppliers who should be able to change this manually.
Check it later on and hopefully it's increased.
 Matthew Wheeler
Cagney1994
Thanks Matthew.
It's increased to about 6.1 which hopefully should stop the connection dropping.  And btw, should the router have restarted itself after that change ?
Fixes: 212
Good to see it's increased.
The router will have lost sync but shouldn't have restarted.
By restart I'm guessing you meant that it lost connection?
 Matthew Wheeler
Cagney1994
Yes, that's what I meant  Smiley
Fixes: 212
Then in that case it's fine.
 Matthew Wheeler
Cagney1994
Will do.
Thanks again.
