Could this message relate to something wrong or wrongly set up in my router?
- Re: Could this message relate to something wrong o...
05-02-2013 7:51 AM
On first boot the Windows Event Log throws up error
Comments please.
I am wondering if might have something to do with how my 582n is set up.
Quote The HomeGroup Listener service terminated with service-specific error %%-2147023143
Comments please.
Message 1 of 7
(1,373 Views)
6 REPLIES 6
Re: Could this message relate to something wrong or wrongly set up in my router?
05-02-2013 8:01 AM
HomeGroup is an idea that came in with Windows 7; sort of Networking for Dummies. I think it is very unlikely that the problem is anything to do with your router unless it's a lost connection to the router - which would manifest in more obvious ways.
Message 2 of 7
(690 Views)
05-02-2013 10:54 AM
I suppose I could be within the dummy spectrum, though I have managed to set things up for a mix of wired and wireless connections. As it is the error seems to give no trouble, so I will leave be.
Thanks for reaasurance.
Message 3 of 7
(690 Views)
05-02-2013 11:19 AM
Is this the only Windows 7/8 PC on your network?
Edit: Also make sure the Windows Firewall service is running (Start > Run > services.msc then find Windows Firewall service and make sure it is set to automatic and is running).
Message 4 of 7
(690 Views)
05-02-2013 11:23 AM
Message 5 of 7
(690 Views)
05-02-2013 3:47 PM
Thanks for posts!
Usually sole computer, but very occasionally relatives have visited with their laptops.
As to Windows firewall, since I have another software firewall ( and doesn't 582n router also have one built in?), why should it be required to also have that installed and active?
But as I said above, I'll leave be.
Message 6 of 7
(690 Views)
05-02-2013 4:05 PM
Firewall in the router is fine, whatever you do on your computer. A software firewall plus Windows firewall should be avoided. Most IS suites turn off Windows firewall during their installation.
I don't know if Kaspersky still does what it did when I had it - it does that at the start of the installation or version upgrade process, long before it starts its own up :(. So I always used to unplug the ethernet cable between the computer and router while it did it.
Message 7 of 7
(690 Views)
