Could this be the same thing?
petecov44
http://www.thinkbroadband.com/ping/share/264af48393ce80cee070410d22380c93-30-07-2014.html
This packet loss has come in and my connection has stopped. I literally can not pull anything through it.
This happened overnight which I guess explains the overnight stuff
http://usertools.plus.net/exchanges/mso.php?id=28474
Could it be happening again?  Yes I can reboot but this is FTTC. I don't want to be flatlined.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Could this be the same thing?
I'd allow for the clear time to pass and if you're still seeing packet loss, I'd look at raising this with our Faults Team.
Chris Pettitt
Cloud Environments Engineer
petecov44
it said it was cleared at 2:50 this morning. Maybe I read that wrong ill re check.
Plusnet Staff
Plusnet Staff
Fixes: 5
Ah yes, you're right. I'd raise a fault in that that case at http://faults.plus.net - you shouldn't be seeing that much Packet Loss!
Chris Pettitt
petecov44
From experience I'll leave it a day or so Chris, I used to get faults raised days after when it had cleared
petecov44
Just had another drop and speed is at 53.4 so lost about 2mbps which is okay.
Tester shows
http://prntscr.com/47zywo
I've lost upload aswell.
