Could this be a net problem?
- Could this be a net problem?
07-11-2009 3:35 PM
Re: Could this be a net problem?
07-11-2009 3:37 PM
07-11-2009 3:38 PM
Your connection is too slow - what does this say https://portal.plus.net/my.html?action=data_transfer_speed
The traffic is being mis-classified - can you try a wireshark - this explains how http://www.plus.net/support/broadband/troubleshooting/wireshark.shtml
07-11-2009 3:42 PM
Try running task manager and see what CPU usage is like when playing.
07-11-2009 4:07 PM
Quote from: adiewoo It's a flash game so it's possible that it is making your PC work hard, is your neighbours lappy newer than yours?
Neighbour's is PC, not so much fussed about the laptop more the PC, they are both custom built and good specs.
Quote from: Oldjim There are two possibilities which come to mind
Estimated line speed:
5 - Checked on 2009-02-24 17:11:39
Current line speed:
6500
Will try the wireshark thing later.
Quote from: adiewoo In the name of research I have just played this and it took my CPU usage for firefox above 80% on a 2.8GHz Core 2 Duo processor, which seems a bit mad.
I use Firefox and it didn't put mine over 60% and i'm using an AMD dual core 7850 2.8GHz so i'd say thats ok.
Thanks for the assistance though, any other ideas?
Re:Could this be a net problem?
09-11-2009 1:00 PM
10-11-2009 9:31 PM
Just to add, I've just done a speed test at speedtest.net and it claims my ping was 245 :o, I know thats bad, why is it so high and could that be having an impact?
10-11-2009 9:45 PM
Are you sure there is nothing else using the network - maybe some background processes are causing the ping issues.
10-11-2009 10:18 PM
11-11-2009 9:12 AM
It's had all kinds of issues recently.
11-11-2009 10:39 AM
Ping is down to 46 this morning, just tried it, it stuttered VERY slightly but nowhere near as bad as normal (i don't normally play it this early!)
11-11-2009 12:19 PM
11-11-2009 5:24 PM
Give Opera a go maybe (if you don't use it already), that's supposed to be very fast. Should be worth a go.
Hope that helps,
11-11-2009 5:39 PM
11-11-2009 5:43 PM
