Could someone show me my radius please?
- Re: Could someone show me my radius please?
17-04-2013 10:41 AM
any chance someone could post my radius chart please.
I have an open Support ticket #68254172
have not had an update since Monday, i filled out a fault report and an OR engineer turned up on Sat AM, i was not aware he would coming so was not in, then the appointment was rebooked for Monday PM the first i heard of this was Monday morning, missed the calls so that appointment got cancelled by you guys, so now am waiting a new appointment.
Not having access to my own OR modem stats is killing me as i can see the drops happening on the box but have no idea what my connection is doing, *sigh* miss my router stats....
17-04-2013 11:23 AM
Script User - Automated Script Pool
11:13am, Wednesday 17 Apr 2013
The broadband fault has been closed by the supplier. Should problems re-occur, please restart the Broadband Fault Checker.
17-04-2013 11:27 AM
It's back with our suppliers already, sorry about that message though. As I put on the ticket we'll get the appointment booked in for you as soon as we can.
Your radius graph:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13661933626366.png"/>
17-04-2013 11:45 AM
still looking bad then
thanks again for the update
17-04-2013 2:25 PM
OR engineer has just turned up at my door, Luckly enough me missus is at home today, will keep you informed as to the result.
17-04-2013 3:01 PM
17-04-2013 8:04 PM
18-04-2013 1:15 AM
18-04-2013 10:30 AM
i have still got the same IP Address as when the OR enginner left, which in my mind says that i have had no disconnects since.
The OR guy told the missus that he had 'changed the port to the cab from the exchange, as he could see a fault 60 meters from my house' not sure if this is right but it looks good so far.
18-04-2013 10:56 AM
It looks like you had a drop yesterday afternoon when the engineer did his work and you were assigned a different IP address which you're still currently connected to.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13662789201666.png"/>
Things certainly look better so far.
