Could someone please check something for me?
I have been having an issue trying to connect to any of my websites hosted with Eukhost since yesterday. I have tried a non Plus Net connection and the server is fine. I have also tried the ip address directly from all of my computers both Windows and Linux but with no luck. I cannot even ping the ip. I have raised a ticket with PN. Could someone please try from another PN connection?
http://91.186.25.13 will take you to a Cpanel test page.
Re: Could someone please check something for me?
No problems accessing the page here.
Try:
Rebooting PC
Rebooting Router/ADSL modem
Disabling any software firewall and Anti-virus Software to see if that is the problem.
Does sound like an problem with your set-up
I have tried all that despite knowing that it would not make any difference. I have also tried flushing Windows DNS although I already knew that this would have no effect as I have tried using all of my computers including my Linux maching running Fedora 8.
Being the webserver that I host websites on I obviously connect to it often and the problem has started without any changes being made to any of my computers or my router.
Can you post a tracert to it?
|                                      WinMTR statistics                                   |
|                       Host              -   %  | Sent | Recv | Best | Avrg | Wrst | Last |
|                               my.router -    0 |   21 |   21 |    0 |    4 |   94 |    0 |
|            lo0.plusnet.thn-ag2.plus.net -    0 |   20 |   20 |   15 |   19 |   32 |   16 |
|                  vl604.thn-gw1.plus.net -    0 |   20 |   20 |   15 |   49 |  234 |   16 |
|                         lonap2.enta.net -    0 |   20 |   20 |   15 |   30 |  187 |   16 |
|            ge-5-2.the.uk.euroconnex.net -    0 |   20 |   20 |   15 |   32 |  203 |   15 |
|        ge-9-1-9-2.tcx.uk.euroconnex.net -    0 |   20 |   20 |   15 |   38 |  125 |   16 |
|                        puma.eukhost.com -    0 |   20 |   20 |   15 |   30 |  188 |   31 |
|________________________________________________|______|______|______|______|______|______|
   WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir  ( stanimir@cr.nivis.com )
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Sean>tracert 91.186.25.13
Tracing route to puma.eukhost.com [91.186.25.13]
over a maximum of 30 hops:
  1     *        *        *     Request timed out.
  2    49 ms    46 ms    48 ms  lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
  3    48 ms    45 ms    46 ms  ge0-0-0-204.ptn-gw02.plus.net [84.92.3.93]
  4    47 ms    46 ms    46 ms  te2-2.pte-gw2.plus.net [212.159.1.106]
  5    48 ms    49 ms    48 ms  te2-4.pte-gw1.plus.net [212.159.1.101]
  6    46 ms    47 ms    48 ms  lonap2.enta.net [193.203.5.135]
  7    47 ms    46 ms    51 ms  ge-5-2.the.uk.euroconnex.net [87.127.231.90]
  8    49 ms    48 ms    59 ms  ge-9-1-9-2.tcx.uk.euroconnex.net [217.112.81.1]
  9     *        *        *     Request timed out.
10     *        *        *     Request timed out.
11     *        *        *     Request timed out.
12     *        *        *     Request timed out.
13     *        *        *     Request timed out.
14     *        *        *     Request timed out.
15     *        *        *     Request timed out.
16     *        *        *     Request timed out.
17     *        *        *     Request timed out.
18     *        *        *     Request timed out.
19     *        *        *     Request timed out.
20     *        *        *     Request timed out.
21     *        *        *     Request timed out.
22     *        *        *     Request timed out.
23     *        *        *     Request timed out.
24     *        *        *     Request timed out.
25     *        *        *     Request timed out.
26     *        *        *     Request timed out.
27     *        *        *     Request timed out.
28     *        *        *     Request timed out.
29     *        *        *     Request timed out.
30     *        *        *     Request timed out.
Trace complete.
That is a bit easier to read!
That is taking the same route as mine except I'm on gateway thn-ag2 (LLU). I wonder if something at their end is blocking your IP address?
I would check if there is any settings on Cpanel/WHM if I could connect to it.
Comparing your trace root with mine, it does appear to be an issue at their end. Will have to email them.
Fixes: 46
No problem loading the page for me on IP Stream (gateway thn-ag1)
C:\>tracert 91.186.25.13
  1    1 ms    <1 ms    <1 ms  192.168.2.1
  2    40 ms    42 ms    42 ms  lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
  3    37 ms    38 ms    35 ms  vl703.thn-gw2.plus.net [84.92.4.242]
  4    36 ms    36 ms    39 ms  te2-3.thn-gw1.plus.net [212.159.1.57]
  5    36 ms    40 ms    39 ms  lonap2.enta.net [193.203.5.135]
  6    35 ms    38 ms    36 ms  ge-5-2.the.uk.euroconnex.net [87.127.231.90]
  7    37 ms    37 ms    35 ms  ge-9-1-9-2.tcx.uk.euroconnex.net [217.112.81.1]
  8    37 ms    38 ms    36 ms  puma.eukhost.com [91.186.25.13]
David
I tried connecting using my Plus Net dial up connection (which obviously has the same static IP) and I got exactly the same results so it is definitely not my Netgear DG834 router. I have emailed Eukhost to get them to investigate the problem. Thanks for your help. Sean.
