Could someone check if my PlusNet Speed Profile needs correcting please?
djbeck
I lost my phone line earlier this week. A "connection fault in the exchange" was fixed by BT/OR engineer yesterday but since then I've only been getting around 37Mb download. I've previously been getting 72Mb download so wondering if my profile has been reset to 40/20 instead of the 80/20 it should be. Could someone check it for me please and correct if necessary.
Dave
apjashley1
Re: Could someone check if my PlusNet Speed Profile needs correcting please?
What does it say under "High Speed Broadband" in your Plusnet members area?
Remeber the DIgital Care Team don't work at weekends.
djbeck
It says 57 estimated and 60.6 as the current speed although I'm not getting anywhere near those at the moment..
You won't get more than your line profile which is 37.56Mbps at the moment.
I think the engineer should have reset your line profile when fixing the fault, as he's the only person that can do it (PN have no control over it). Your line speed should increase automatically as long as the fault is fixed and your line is stable, but without a manual reset this can take weeks I believe.
Make sure you keep your router/BT modem on all the time and if you need to disconnect, do it from the router admin page.
djbeck
ok, thanks for your help
It's worth adding to your support ticket if you've got one open, or create a new one, that you want the IP Profile for your line reset so PN can request this from BT.
djbeck
Ticket number 67168556 raised
Thanks for that, I can see it's with our faults team - they should be coming back to you with an update soon. Hope it gets sorted quiclkly for you.
djbeck
Hi, could you give me an update please? I've not heard anything since I raised the ticket.
Plusnet Staff
Plusnet Staff
Fixes: 5
It's still with our Faults Team and it's due to be picked up today.
Sorry for the delay.
Chris Pettitt
Cloud Environments Engineer
djbeck
No problem, thanks for the update Chris
Regards
Dave
