Could someoen help me check my line please
- Could someoen help me check my line please
07-04-2012 3:28 AM
Statistics -- ADSL Line
Mode G.dmt
Latency Interleave
Trellis Coding Disable
Status SHOWTIME.
Power Level L0
Uptime 12:21:53
Downstream Upstream
SNR Margin (dB) 15.7 22.0
Attenuation (dB) 42.5 27.0
Output Power (dBm) 19.5 11.5
Attainable Rate (Kbps) 4992 1064
Rate (Kbps) 4640 448
K (number of bytes in DMT frame) 0 15
R (number of check bytes in RS code word) 0 16
S (RS code word size in DMT frame) 655.35 8.00
D (interleaver depth) 1 2
Delay (msec) 655.35 4.00
FEC 139487 8
CRC 555 6
Total ES 286 5
Total SES 1 0
Total UAS 0 0
Re: Could someoen help me check my line please
07-04-2012 10:55 AM
Are you getting a lot of disconnections? Do you leave your router on permanently?
07-04-2012 11:33 AM
07-04-2012 1:16 PM
07-04-2012 2:06 PM
Mind you that is not the only odd thing
D the interleaver depth is given as 1 for downstream and 2 for upstream
So that means downstream is not Interleaved (ie is Fastpath) and upstream just has a mini-amount of interleaving on it
So if there is no downstream interleaving why are there FEC corrections downstream listed?
If it is a fastpath line then there should be none as there is no Forward errror corrections being done.
(Unless the router report data in the post is corrupted of course)
I know the latency say 'interleaved' - but my router says I'm on fast - and then goes on to report the interleaver depths as 64/4 correctly
Mind you for a 42 DB attenuation line I'd have though interleaving really should be on with a significant depth.
As Jelv's says downstream SNR looks high - the exchange must have raised it form the standard of 6 to 9 and then 12. Perhaps the line either suffers disconnections for no reasons or extremely variability - ie sudden impulse 'noise' from somewhere which comes and goes
Beyond my technical competance.......
07-04-2012 2:42 PM
Quote from: jelv Your noise margin is high. The exchange does this when it thinks the line is unstable and raises the target to try and get it stable - this reduces the speed.
I do get some strange veneration on speed and the odd log off.
I try and keep it on all the time yes
07-04-2012 2:46 PM
Should I wait. I can't really understand a lot of this
Can't find anywhere to change the Trellis settings
07-04-2012 2:50 PM
It will only happen when Plusnet request the move but whether it solves the problem I have no idea - it certainly helped sort mine where I was getting disconnections whenever the phone rang even if no phone was connected
07-04-2012 4:08 PM
SNR Margin (dB) 16.6 22.0
Output Power (dBm) 19.5 12.0
Attainable Rate (Kbps) 4892 1060
Rate (Kbps) 4512 448
K (number of bytes in DMT frame) 142 15
R (number of check bytes in RS code word) 12 16
S (RS code word size in DMT frame) 1.00 8.00
D (interleaver depth) 16 2
Delay (msec) 4.00 4.00
FEC 139 0
10-04-2012 12:45 PM
Can you tell me if you're using any extension cables/sockets? Do you have a test socket you can plug into?
Jojo
10-04-2012 4:48 PM
No tester.
10-04-2012 5:35 PM
I could reset the SNR to 6dB, which would bring your sync rate back up. The downside to this is that it could still go back up, as we've no idea what caused it. If that happened then we couldn't do anything about it for a further 10 days.
Jojo
10-04-2012 6:37 PM
10-04-2012 6:57 PM
If it doesn't work soon, try asking Plusnet for a test router - it's the same as an ordinary router.
You could just return it if it makes no difference, or pay £5 to keep it.
10-04-2012 7:14 PM
Its BTs fault
Its Plusnets fault
Well I know its not mine and Plusnet is owned by BT they should talk.
I'm paying top wack for a dial up connection.
