Could some please look at my profile ?
- Could some please look at my profile ?
17-09-2012 10:36 AM
just checked my sync etc and router data rate has gone up 8020, but have lost a meg of my download speed ... everything has been solid as rock for over 5 days and i was expecting an increase in speed if anything ... checked router log and there are a whole host of ppp Events ... which all correspond to me plugging my phone in to make some calls ..( phone is not usually plugged in) as i dont use it regularly .
is possible to do something to bring my speed back up to were it should be /was . SNR
1. Best Effort Test: -provides background information.
Download Speed
5.45 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 5.45 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.07 Mbps
Upload Speed
0.91 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.91Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Re: Could some please look at my profile ?
17-09-2012 11:00 AM
17-09-2012 11:08 AM
17-09-2012 11:12 AM
Have you tried a different filter
the fact that the IP profile hasn't increased immediately could indicate a profile mismatch within the BT systems or, just possibly as I may be talking rubbish, that the system has capped the IP profile because of the high number of drops in PPP
17-09-2012 11:16 AM
17-09-2012 11:20 AM
Anyway I will let you get on with trying to get the BT profile changed
17-09-2012 11:23 AM
17-09-2012 2:45 PM
I've adjusted your line profile to according to your sync speed so you should now see an improvement with your speeds.
It certainly looks like your line is stable since we last work. How are things your end?
Chris
17-09-2012 2:53 PM
17-09-2012 5:28 PM
thanks for that , at present no change
current router stats
Jeiv ...thanks for the info ..maybe i should invest in a fully functioning hand set
ADSL
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 8020 888
Noise Margin 5 10
Output power(dBm) 12 20
Attenuation(dB) 43 25
as you will have seen it was solid until this morning , these were caused by me , never thought it would effect anything ... do you think i should restart router ?
cheers
wayne
17-09-2012 5:32 PM
17-09-2012 6:40 PM
well that went a bit mental ..Disconnected from my router using interface , powered off for a minute or 2 , powered back up ... and it just said "Can't find NTP time".
wouldnt connect to internet ...then there was another ATM1 PPP event and it would then connect ..Router stats are now .
ADSL
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 7785 888
Noise Margin 5 11
from bt speedtest i now get
FAQ
Download Speed
6.4 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 6.4 Mbps
IP Profile for your line is - 6.87 Mbps
Upload Speed
0.82 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.82Mbps
But if i do JDs autospeed test it says can not connect to wan
any ideas
18-09-2012 2:52 PM
How is you WAN connection? Is it working?
Your line is currently performing how it should be.
Let me know how you get on.
18-09-2012 4:08 PM
thanks again for the reply , at the time of "Can't find NTP time" i couldnt connect to the internet even though i had green light on router , my wan connection seems to be working fine , but still get the same message from jd speed test .
but connection does seem to be working fine at the moment
thanks
20-09-2012 11:34 AM
things have been ok past couple of days , so did router restart this morning ...
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 7990 888
Noise Margin 5 10
Output power(dBm) 102 0
but speed dropped .....
and just typing this message got a ppp event and now
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 7755 888
Noise Margin 5 10
and speed has gone up ..yo yo springs to mind ...
bt test figures
Download Speed
6.16 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 6.16 Mbps
IP Profile for your line is - 6.84 Mbps THIS HAS DROPPED from 7.05 Mbps This morning ????
Upload Speed
0.9 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.9Mbps
aahhhh
