Could BT Openreach work have reduced my broadband speed?
- Could BT Openreach work have reduced my broadband ...
- « Previous
- 1
- 2
- Next »
Re: Could BT Openreach work have reduced my broadband speed?
01-12-2014 6:40 PM
The banding is caused to ensure the connection remains stable. Since the phone fault has been resolved, I've reset the line for you. The banding should be removed within the next few hours, but it may take a little longer for you to get the new throughput.
Tony
03-12-2014 9:51 AM
08-12-2014 2:52 PM
Tried to run a test direct into the master socket at the weekend but I discovered that the ADSL plug into the router is a different shape to the one exiting the master socket (its one of those twin ADSL ones). So how do I connect the router to the master socket?
08-12-2014 3:53 PM
The banding isn't on your line any-more and the sync is better but there's a fair few errors on the line which won't be helping things.
With regards to the faceplate does it look like any of the ones in the link below?
http://www.plus.net/support/broadband/master-socket-guide.shtml
08-12-2014 4:24 PM
Attaching a picture of the ADSL face plate...cable runs form this to an extension box, which has a smaller plug into the router
08-12-2014 4:26 PM
It looks like you have a filtered faceplate. One socket for the phone and for the broadband.
If you unscrew the two screws you should be able to get to the master socket which is behind it.
08-12-2014 4:44 PM
Please leave the line unbanded in the meantime even if there are occasional drops, thanks.
09-12-2014 12:50 PM
The only other thing that it would be helpful to confirm is the colour of the 2 wires from the faceplate to the modem/router socket - I would hope they would be a pair of either Blue+white trace & White+blue trace, or Orange+white trace & White+orange trace.
09-12-2014 3:27 PM
Should the quiet line test also be done direct into the master socket?
09-12-2014 6:15 PM
09-12-2014 7:34 PM
As something has caused your speeds to drop and DLM to have banded your connection, it would be best to ensure any future disconnecting is done "gracefully". Use the following method -
If you have a modem/router that doesn't have an interface for you to drop the PPP session, then pull the power plug and wait a minute or two before unplugging from the line, otherwise -
Log in to the Modem/Router, in the Internet box, click Disconnect to drop the PPP Internet session (this is not the sync), wait about a minute and then power down the Modem/Router. After about another minute you can unplug it from the line.
Do whatever is needed (swap filters/sockets etc), but stay offline for at least 10 minutes. When you re-connect and power up, and when it's booted, Login to the Modem/Router and click Connect to establish a new PPP session.
Don't do this more than 5 times in an hour, then leave it for the rest of the day. This method is to help stop the Exchange DLM from thinking your sync loss was a dropped connection.
One further point, especially applicable to very long lines, you will get very small differences in sync speed every time you sync, so just because you get a marginally better sync speed in one situation, it doesn't necessarily mean that situation is better than another situation.
The other thing particularly for long lines, is to do this in daylight hours, in Winter a good hour after sunrise and a good hour before sunset when propagation noise levels tend to be at their lowest.
- « Previous
- 1
- 2
- Next »
