Cookie prompts from my own IP ???
- Re: Cookie prompts from my own IP ???
15-10-2013 10:28 AM
Not sure if this is the right place, but as it's to do with my internet connection:
I'm currently trying out another browser (Pale Moon). All set up yesterday and all running fine. Today when I open the browser I get a series of about twenty cookie prompts from an IP address. When I check that address I find it's the one I'm currently assigned. Does anybody have any idea why I would get such prompts from my own IP address?
Message 1 of 9
(1,470 Views)
8 REPLIES 8
15-10-2013 10:31 AM
What page is the browser trying to open? Has Pale Moon set a local file as your homepage?
Scrub that - It wouldn't explain why the cookies are from your WAN address
Message 2 of 9
(712 Views)
15-10-2013 11:06 AM
Probably doesn't help but I use Pale Moon as my usual browser both on Plusnet at home and BT Business at work, I have never experienced cookie prompts from my own address.
What homepage is set in the browser?
Call me 'w23'
Message 3 of 9
(712 Views)
15-10-2013 11:18 AM
I have, like Firefox, set about:blank as the homepage, and when both start they are both set to use a blank page.
Message 4 of 9
(712 Views)
16-10-2013 2:09 PM
I have managed to stop the cookie prompts by changing my settings in Pale Moon, which it transpires were slightly different to the settings I have in Firefox. For anyone else experiencing the same and who may come to read this, change the following settings:
Tools/Options/Privacy - In the History section, select Pale Moon (or Firefox) will: Use custom settings for history which expands further settings - Tick Accept cookies from sites - Accept third-party cookies: Never.
It was set to the default 'Always', hence the prompt. It doesn't, however, explain why I should be getting cookies from my own IP address precisely.
Message 5 of 9
(712 Views)
16-10-2013 4:48 PM
Did you ever see what info was being set in said cookies? It may hold the clue to where it's coming from.
That's RPM to you!!
Message 6 of 9
(712 Views)
18-10-2013 12:07 PM
Only ever saw random characters on them.
Message 7 of 9
(712 Views)
18-10-2013 12:21 PM
What if anything do you get if you open your WAN IP address in a web browser?
You could also check for open ports on http://canyouseeme.org/ and use TCPView to see what's running on your computer.
Message 8 of 9
(712 Views)
18-10-2013 2:18 PM
I get my router login page when I open my IP address in my browser. I already know from previous checking that my ports are stealthed. The typical view via TCPView of what's running is in the attached image.
Message 9 of 9
(712 Views)
