Converted room into study - HELP!!!
- Converted room into study - HELP!!!
- « Previous
- Next »
Re: Converted room into study - HELP!!!
26-10-2012 1:10 PM
Quote from: jelv CAT 6 snagless - that future proofs you up to gigabit.
Nope. You only need Cat5e for that.
Message 61 of 66
(503 Views)
26-10-2012 1:16 PM
Glad you're getting there.
All mine is cat5e and that runs fine at 1 gig, even my network here at work which is cat5e and must be getting close to 100 meters but runs fine at 1 gig.
Message 62 of 66
(503 Views)
26-10-2012 1:18 PM
And Cat6 is fine.
Message 63 of 66
(503 Views)
26-10-2012 1:25 PM
Cat 5e should be OK, but as noted higher up some suppliers give you Cat 5 instead. For the small amount extra I'd go go with Cat 6 for the comfort factor - it's also a bit more robust when you start dragging it round a house.
Message 64 of 66
(503 Views)
26-10-2012 2:04 PM
It was expensive tho! should be worth it
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 65 of 66
(503 Views)
26-10-2012 3:22 PM
Expensive? On eBuyer I'm looking at Cat 6 snagless 30M in a variety of colours all for under £10: http://www.ebuyer.com/search?a00436=30&subcat=2427&cat=24
Message 66 of 66
(503 Views)
- « Previous
- Next »
