Converted room into study - HELP!!!
- Converted room into study - HELP!!!
Re: Converted room into study - HELP!!!
26-10-2012 11:45 AM
26-10-2012 11:47 AM
You could also look on Amazon as there's plenty available on there at very good prices.
Edit: Anotherone posted while I was composing my post and looking on Amazon!
26-10-2012 11:50 AM
26-10-2012 11:51 AM
26-10-2012 11:56 AM
26-10-2012 12:01 PM
http://www.amazon.co.uk/CAT5e-ETHERNET-NETWORK-PATCH-CABLE/dp/B000IAHNRK/ref=sr_1_5?s=computers&ie=U...
Could you help me find some cheap cable clips?
adie:quote
26-10-2012 12:04 PM
If they are just going into plaster/wood then cheap ones of the right size from Amazon will do
26-10-2012 12:19 PM
26-10-2012 12:20 PM
Quote from: Geordiegal Can this decrease speed? using a long ethernet cable?
Yes long Ethernet cables can cause problems if either it's not Cat 5e or it's more than 100m long. Unless you live in a mansion you won't have problems!
26-10-2012 12:27 PM
26-10-2012 12:30 PM
30 m ethernet cable
100 cable clips
26-10-2012 12:32 PM
26-10-2012 12:34 PM
26-10-2012 12:38 PM
and just some normal 100 clips
All from amazon
26-10-2012 1:04 PM
