Converted room into study - HELP!!!
- Converted room into study - HELP!!!
24-10-2012 8:14 PM
Is it possible to move my modem into study? Don't want homeplugs or wifi adapters. I want to use my telephone socket thats in the study.
Any help appreciated!
Re: Converted room into study - HELP!!!
24-10-2012 8:37 PM
24-10-2012 8:56 PM
If that doesn't work out buy a pair of homeplugs. I've been very happy with these: http://www.amazon.co.uk/TP-Link-TL-PA211KIT-200Mbps-Powerline-Ethernet/dp/B004INVKP4/
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
24-10-2012 8:59 PM
Quote from: Oldjim you can try - see what effect it has on your connection speed and stability
BUT HOW
24-10-2012 9:03 PM
24-10-2012 9:09 PM
Edit: just seem you've edited your post to be less dogmatic. My experience was no problem (and one of the plugs was on a 4 gang extension lead!).
24-10-2012 9:22 PM
adie:red all caps post edited as per link:rules
24-10-2012 9:29 PM
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
24-10-2012 9:34 PM
adie:quote
24-10-2012 9:37 PM
You're pretty much stuck, unless you run ethernet cable from your modem to your study.
24-10-2012 9:45 PM
24-10-2012 9:47 PM
24-10-2012 9:47 PM
You can use homeplugs to connect the modem to the router so leave the modem where it is and put the router in the study.
24-10-2012 9:51 PM
If you just want phone in there you can legitimately run CW1308 (2 pair) from the IDC terminals 2 & 5 from the NTE front plate to an extension socket.
24-10-2012 9:55 PM
