Continuing issues with Overwatch
alexmanessi1
I've been having issues with the quality of the connection to Overwatch servers for a number of weeks now. I've been following forum posts on various sites about it and that it was somehow related to IPs starting with 50 range with a fix being to get the ISP to give you a static IP.
Apparently PlusNet have been aware of the issue and have worked to fix it. I however, have ended up purchasing the static IP and found that I still have issues. The IP I have now starts with 212 and while I'm no longer getting the same map loading loop I used to have I am now experiencing extreme lag spikes. When it's fine I have ping that ranges between 25-40ms and when it spikes it hits 2000ms making the game unplayable.
These spikes don't just affect the game as they affect general browsing too and the only way to get them to drop seems to be to turn off the game though I realise this could be coincidental but it's what I've experienced so far.
The Overwatch IP in Europe is 185.60.112.157
Fixes: 64
Re: Continuing issues with Overwatch
Can you run a traceroute to that IP please so we can dig further.
 Adam Walker
alexmanessi1
Will do. Unfortunately I won't be home until Sunday so will have to get back to you then.
Fixes: 64
No worries, it will help us investigate the matter so please drop us a reply here when you've been able to do it.
 Adam Walker
alexmanessi1
Hi, I was finally able to get round to running the traceroute.
Here it is:
Tracing route to 185.60.112.157 over a maximum of 30 hops
1 1 ms 1 ms 1 ms dsldevice.lan [192.168.1.254]
2 2010 ms 2017 ms 1983 ms lo0.10.central10.ptw-bng01.plus.net [195.166.128.170]
3 1981 ms 1980 ms 1964 ms irb.10.PTW-CR02.plus.net [84.93.249.2]
4 844 ms 613 ms 561 ms 195.99.126.182
5 305 ms 325 ms 320 ms host213-121-193-190.ukcore.bt.net [213.121.193.190]
6 323 ms 315 ms 314 ms 213.137.183.36
7 1321 ms 1358 ms 1349 ms t2c3-xe-1-0-0-0.nl-ams2.eu.bt.net [166.49.208.216]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Hope this helps.
alexmanessi1
Were you able to look into this? I'm still getting these random spikes in lag.
