Continuing email problems
- Continuing email problems
16-10-2007 8:53 PM
I am still experiencing problems receiving re-directed mail from an old ISP. It is for live email accounts but for which I still receive mail and I need to get hold of it but the connection keeps timing out before the mail has downloaded to your servers. When will it be fixed?
Message 1 of 4
(1,274 Views)
3 REPLIES 3
Re: Continuing email problems
16-10-2007 11:09 PM
I'm not 100% sure what your problem is. How is the mail redirected and who through?
Am I correct that you're redirecting mail /from/ an old ISP /to/ a Force9 address?
What happens when somebody tries sending an email to the address or is it problems logging onto our server to retrieve the messages that you're having difficulty with? If it's the latter then how are you trying to collect the email? Using Webmail or a standalone mail client like Outlook?
Message 2 of 4
(364 Views)
19-10-2007 7:17 AM
I have email accounts with virgin.net which I receive using my plus.net braodband connection. I also use Mailwasher to view the messages before downloading them to my PC so that I can eliminate spam and messages that look like they might have viruses attached. From Mailwasher I then download the messages to Outlook. It is when running Mailwasher, when the plus.net server attempts to connect to the virgin.net server that I seem to have problems, with it saying that the connection has timed out or the network is down (when it isn't at my end). The problem does seem to have settled down over the past couple of days though.
Message 3 of 4
(364 Views)
19-10-2007 12:54 PM
Increasing the Server Timeout setting in Outlook (More Settings/Advanced tab in OL2003) for the relevant email account might help. I use values larger than the default for access to external servers.
David
Message 4 of 4
(364 Views)
