Continued slow speed
keithjthomas
My SPEED in Lynton, Devon is APPALLING and has been for weeks!!
Download is 350kbs - Up is 249kbs
It used to be 1.2mps!!
cedlor
Re: Continued slow speed
It is not much use posting then not following up with the information needed for members to try and help.
You need to complete all the tests here  https://community.plus.net/forum/index.php/topic,143835.0.html
and post the results.
Also  as  Spoonwhittler said in January
    spoon whittler
    Bright Spark
    microsoft_passport@elvin.plus.com
    View Profile Personal Message (Offline)
« Reply #1 on 24/01/2014, 13:25 »
Have you tried using the test socket?
Are you connected to the router wired or wireless? (If you are wireless you need to test wired)
Have you raised a fault? http://faults.plus.net
keithjthomas
Problem sorted - after running BT full test speed is back to normal (why?) 1.2gbs not good but normal! Smiley
cedlor
Well that is good news Smiley
If it is an intermittent line fault, it could return in which case the  router stats may help shed light on it.
