Continued slow speed
- Re: Continued slow speed
23-09-2015 11:36 AM
My SPEED in Lynton, Devon is APPALLING and has been for weeks!!
Download is 350kbs - Up is 249kbs
It used to be 1.2mps!!
Message 1 of 4
(768 Views)
3 REPLIES 3
23-09-2015 4:17 PM
It is not much use posting then not following up with the information needed for members to try and help.
You need to complete all the tests here https://community.plus.net/forum/index.php/topic,143835.0.html
and post the results.
Also as Spoonwhittler said in January
spoon whittler
Bright Spark
microsoft_passport@elvin.plus.com
View Profile Personal Message (Offline)
« Reply #1 on 24/01/2014, 13:25 »
Have you tried using the test socket?
Are you connected to the router wired or wireless? (If you are wireless you need to test wired)
Have you raised a fault? http://faults.plus.net
spoon whittler
Bright Spark
Message 2 of 4
(612 Views)
23-09-2015 8:24 PM
Problem sorted - after running BT full test speed is back to normal (why?) 1.2gbs not good but normal!
Message 3 of 4
(612 Views)
23-09-2015 10:22 PM
Well that is good news
If it is an intermittent line fault, it could return in which case the router stats may help shed light on it.
Message 4 of 4
(612 Views)
