Continual disconnects
nomadpete1978
I'm having some severe issues recently - particularly the last three days - where my DSL constantly disconnects. It may hold for an hour or so, but then bombs out completely and dies. Sometimes forcing a manual reconnect through my router works, sometimes it doesn't, sometimes it recovers for only a minute or two. It's becoming intolerable.
This has only happened since I upgraded my account - only the speed, not type - and am wondering if this has triggered something?
For reference, I use a TPLink Archer VR600 router, not the supplied router from PlusNet, so have had to enter the PPPoE information to enable the connection. This has been fine for years before now; could the change in account type trigger something that means these details are now wrong? Although I guess that would mean it would never work if that were the case.
Help!
8 REPLIES 8
Fixes: 374
Re: Continual disconnects
@nomadpete1978 This sounds more like a BT/OR issue, or even a failing modem/router. Can you get any useful statistics/data off that kit to at least give us a clue what might be happening?
nomadpete1978
I've just tried a quiet line test, and that seems to be clear.
The router however is not presenting the best picture:
  Upstream Downstream
Current Rate (kbps)1999854879
Max Rate (kbps)2225055150
SNR Margin (dB)6.85.3
Line Attenuation (dB)36.113.3
Errors (pkts)0544
This is over an 8 hour period since the last drop when it has barely been used.
The simple self-test diagnostics in the router seem to suggest it is fine; the logging isn't great in there however. There is this sequence in the system log, however:
12022-08-04 23:19:07SYSTEMNoticeDSL Link Up us/ds 19998/54879 kbps Type PTM
22022-08-04 23:19:05SYSTEMNoticeDSL Training G.993 Channel Analysis
32022-08-04 23:18:54SYSTEMNoticeDSL Training G.993 Started
42022-08-04 23:18:53SYSTEMNoticeDSL G.994 Non-Standard Info Received
52022-08-04 23:18:51SYSTEMNoticeDSL G.994 Non-Standard Info Received
62022-08-04 23:18:46SYSTEMNoticeDSL Training G.994
72022-08-04 23:18:41SYSTEMNoticeDSL Link Down
Fixes: 374
@nomadpete1978 That data is useful - the DSL data looks OK, but the DSL down in the logs suggests an problem somewhere -  how many of these have occurred in whatever time period your logs cover?
Can you post the results from: https://www.broadbandchecker.btwholesale.com/#/ADSL and https://speedtest.btwholesale.com/ , reporting the 'Additional Diagnostics result, please.
OldBen
Hi Pete,
I've run a test on your line today and have detected a potential issue.
You had 84 drops on the 4th and it looks like the speed has been fluctuating as a result.
My testing has picked up bridge tap. This is typically a second pair of wires running across a service in the home. This can cause unwanted signal reflections and the usual culprits tend to be things like extension cables and old doorbell wiring.
If you've got any extension sockets try and disconnect them and see if you have any improvement.
If this doesn't help then we can always look at getting an engineer round to identify the source of the bridge tap and resolve the issue.
Hope to hear from you soon,
Ben.
PNHelp100x100(biglogo).png  Ben
 Plusnet Staff
Fixes: 374
@OldBen - welcome to the madhouse. 😀
OldBen
The community mailer for getting password reset links seems to be working now so I can finally get in and lend a hand. I've been locked out for a few months now unfortunately but glad to be here now.
 Plusnet Staff
PeeGee
@nomadpete1978
"The simple self-test diagnostics in the router seem to suggest it is fine; the logging isn't great in there however."
That, presumably, is the default. My last re-sync generated 48 lines in the log, but I have it set for:
Type: ALL
Level: DEBUG
which records just about everything going on, including Plusnet "gateway" changes.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
CrystalJayme
Sorry, wrong post. I can't delete as there's no option so I've edited this comment.
