Constantly having to swap channels
iLoVeLeMoNs
Hi, I've been a Plusnet user for about a month now and I'm finding the wireless has problems connecting. Almost everyday I have to connect to the router using the wire and change channels which is quite annoying. Can anyone help?
Fixes: 23
Re: Constantly having to swap channels
For reasons best known to themselves, Plusnet are currently sending out Thomson routers which, it has been found, often give problems with wireless.  There is an update available for the router firmware that cures most of the wireless problems but Plusnet send out the routers regardless and don't spontaneously tell you about the firmware update.
iLoVeLeMoNs
Thanks RR! Whereabouts do I find this update?
iLoVeLeMoNs
It's ok I've seen it at the sticky at the top. Thanks again!  Smiley
